StarTech.com 3 ft Mini DisplayPort 1.2 Cable M/M - Mini Displ...
StarTech.com 3 ft Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k
£11.96
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Guaranteed reliability
  • Type: DisplayPort
  • Length: 91cm
  • Stock Status: In Stock
Product codes
Create a high-resolution 4k x 2k connection with HBR2 support between your Mini DisplayPort-equipped laptop and monitor. The MDISPLPORT3 3ft Mini DisplayPort 1.2 cable features 2 Mini DP male connectors, and offers a dependable solution for connecting any Mini DisplayPort-enabled laptop (including Mac family of products) to a Mini DisplayPort-equipped monitor.
The mDP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
Newer laptop and desktop computers (e.g. Apple) come equipped with Thunderbolt ports only. The Mini DisplayPort Cables can be connected to the Thunderbolt ports, enabling you to connect your Mini DP compatible displays.
Product Description StarTech.com 3 ft Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k - DisplayPort cable - 91 cm
Type DisplayPort cable
Length 91 cm
Connector Mini DisplayPort - male
Connector (Second End) Mini DisplayPort - male
Compliant Standards RoHS
Colour Black
Designed For P/N: DP2MDPMF6IN
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3 ft Mini...
£11.96
