StarTech.com 3 ft Mini DisplayPort to DVI Adapter Converter C...
StarTech.com 3 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - White
£16.18
18 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Connect a Mini DisplayPort source directly to a DVI monitor or projector, with a single male-male cable
  • Stock Status: In Stock
Product codes
Connect a DVI display to a Mini DisplayPort-equipped PC or MAC over a short 3 foot distance, with a tidy installation - White. The MDP2DVIMM3W Mini DisplayPort to DVI Adapter Cable lets you directly connect your Mini DP video source (Desktop PC, Laptop, Ultrabook etc.) to a DVI monitor, projector, eliminating the expense of having to upgrade to a Mini DisplayPort-capable monitor.
The adapter cable is 3 feet (1m) in length, and features male-to-male connectors, allowing you to connect your Mini DisplayPort source directly to a DVI display with no additional cabling required.
Compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port, the adapter supports resolutions up to 1920x1200 (WUXGA).
MDP2DVIMM3Wis a passive adapter that requires a dual-mode DisplayPort port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
Product Description StarTech.com 3ft Mini DisplayPort to DVI Adapter Cable Mini DP to DVI White - DisplayPort cable - 91.44 cm
Type DisplayPort cable
Features Thumbscrews
Length 91.44 cm
Connector Mini DisplayPort - male
Connector (Second End) DVI-D - male
Compliant Standards FCC, RoHS
Colour White
Image Colour Disclaimer The displayed product image may be a different colour
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3 ft Mini...
£16.18
