StarTech.com 3 ft Mini USB Cable - A to Left Angle Mini B
£4.06
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
  • Length: 91cm
  • Stock Status: In Stock
Product codes
Connect your Mini USB devices, with the cable out of the way. The USB2HABM3LA 3ft USB to Left Angle Mini USB Cable provides a high quality connection between your Mini USB 2.0 mobile devices (smartphones, GPS, digital cameras, portable hard drives, etc.) and your PC or Mac computer, for everyday tasks such as charging, data synchronization or file transfers.
The left-angled Mini USB connector allows you to access your Mini USB devices, while keeping the cable out of the way, and stress away from the port.
As an alternative, StarTech.com also offers a USB2HABM3RA 3ft USB A to Right Angle Mini B, which provides the same convenience as this left-angled cable, but allows you to connect to your Mini USB device from the opposite direction.
Product Description StarTech.com 3 ft. (0.9 m) Left Angle Mini USB Cable - USB 2.0 A to Left Angle Mini B - Black - Mini USB Cable (USB2HABM3LA) - USB cable - 91 cm
Type USB cable
Features 90° connector, left-angled connector
Length 91 cm
Connector 4 pin USB Type A - male
Connector (Second End) Mini-USB Type B - male
Compliant Standards USB / USB 2.0
Colour Black
Designed For P/N: SV565HDIP
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3 ft Mini...
£4.06
