StarTech.com 3 ft Panel Mount USB Cable USB A to Motherboard...
StarTech.com 3 ft Panel Mount USB Cable  USB A to Motherboard Header Cable F/F
£5.55
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Configure your systems as needed, extend your USB motherboard connection by 3ft
  • Customize your solutions by mounting a USB-A port on your PC
  • Guaranteed reliability
  • Length: 90cm
  • Stock Status: In Stock
Product codes
Connect a panel mount USB-A port to your motherboard header. The USBPNLAFHD3 3ft Panel Mount USB Cable enables you to add a well-secured, easy to access USB 2.0 port to your PC, offering a convenient solution for connecting bootable thumb drives or authentication fobs etc. to the motherboard USB connection.
The adapter features one female USB header connector and one female panel mount USB-A port and gives you an extension of 3ft, enabling you to place the cable as needed within the system case.
Product Description StarTech.com 3 ft Panel Mount USB A to Motherboard Header Cable F/F - USB internal to external cable - 90 cm
Type USB internal to external cable
Length 90 cm
Connector 5 pin USB 2.0 header - female
Connector (Second End) 4 pin USB Type A - female
Compliant Standards USB / USB 2.0
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3 ft Pane...
£5.55
