StarTech.com 3 ft Panel Mount USB Cable A to B - F/M
£5.58
14 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Configure your systems as needed, extend your USB-B connection by 3ft
  • Customize your solutions by adding internal USB-B devices that connect through a USB-A port
  • Guaranteed reliability
  • Length: 91.4cm
  • Stock Status: In Stock
Product codes
Mount your USB device internally and connect to it through a panel mount USB-A connection. The USBPNLAFBM3 3ft Panel Mount USB-B Cable provides a well-secured, easy to access USB-A port on your PC or on a faceplate, allowing you to customize your systems to suit your needs. Perfect for podiums, kiosks and other solutions where added access to USB peripherals is required.
The adapter features one male USB-B connector and one female panel mount USB-A port allowing you to mount your USB device internally enabling you to access it through a USB-A connection. Offering 3ft in cable length, the adapter allows you to place the cable as needed within the system case.
Product Description StarTech.com 3 ft Panel Mount USB Cable A to B - F/M - USB extension cable - 91.4 cm
Type USB extension cable
Technology Double shielded
Length 91.4 cm
Connector 4 pin USB Type A - female
Connector (Second End) 4 pin USB Type B - male
Compliant Standards USB / USB 2.0
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3 ft Pane...
£5.58
