StarTech.com 3 ft Slim High Speed HDMI Cable with Ethernet -...
StarTech.com 3 ft Slim High Speed HDMI Cable with Ethernet - HDMI to HDMI Mini M/M
£8.94
14 in stock
Delivery:
Standard: 1-3 working days
  • Type: HDMI
  • Length: 91cm
  • Stock Status: In Stock
Product codes
Connect HDMI Mini-equipped devices to displays incorporating HDMI technology, with minimal clutter, maximum quality and Ethernet Data Channel Support. The HDMIACMM3S 3-foot Slim High Speed HDMI to HDMI Mini cable supports advanced capabilities including Ethernet data interconnectivity with compatible HDMI-enabled devices, and features a thin cable design (3.5mm in diameter) suitable for installations with tight space requirements.
This High Speed HDMI to HDMI Mini cable lets you connect devices with an HDMI Mini (type C) port to a display/device with an HDMI (type A) port - a cost-saving solution for connecting cutting-edge and next-generation HDMI-capable devices to existing HDMI technology.
The HDMI/HDMI Mini cable features high quality gold-tipped connectors that ensure peak connectivity.
Product Description StarTech.com 3 ft Slim High Speed HDMI Cable with Ethernet - HDMI to HDMI Mini M/M (HDMIACMM3S) - HDMI with Ethernet cable - 91 cm
Cable HDMI with Ethernet cable
American Wire Gauge (AWG) 36
TMDS Links Single link
Length 91 cm
Colour Black
Connector HDMI - male
Connector (Second End) Mini HDMI - male
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3 ft Slim...
£8.94
