StarTech.com 3 ft Slim High Speed HDMI Cable with Ethernet -...
StarTech.com 3 ft Slim High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable
£7.94
47 in stock
Delivery:
Standard: 1-3 working days
  • Length: 91cm
  • Stock Status: In Stock
Product codes
Create Ultra HD connections between your HDMI-enabled devices with minimal clutter; supports Ethernet Data Channel. The HDMIMM3HSS 3-foot Slim High Speed HDMI Cable supports advanced capabilities, including Ethernet data inter connectivity with compatible HDMI-capable devices, and features a thin cable design (3.5mm in diameter).
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
StarTech.com High Speed HDMI cables are expertly designed and constructed of only top quality materials to ensure high quality and high definition performance.
Product Description StarTech.com 3 ft Slim High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable M/M - 3ft Slim HDMI Cable - 3ft HDMI Cable (HDMIMM3HSS) - HDMI with Ethernet cable - 91 cm
Cable HDMI with Ethernet cable
American Wire Gauge (AWG) 36
Length 91 cm
Colour Black
Connector HDMI - male
Connector (Second End) HDMI - male
Designed For P/N: SV431DHD4KU, SV431HDU3A2
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3 ft Slim...
£7.94
