StarTech.com 3 ft Straight Through Serial Cable - DB9 M/F
£3.96
29 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Allows you to extend the reach of your serial devices by up to 3ft, reducing cable length restrictions and providing flexibility for positioning your serial devices as needed
  • Backed by StarTech.com lifetime warranty
  • Length: 90cm
  • Stock Status: In Stock
Product codes
Extend the connection between your DB9 serial devices by up to 3 ft. The MXT1003 Serial Extension Cable features one DB9 male connector and one DB9 female connector, providing a high quality extension for your serial devices which enables you to position your peripheral devices as needed.
This DB9 extension cable is expertly designed and constructed of top quality materials to ensure durability.
Product Description StarTech.com 3 ft / 91cm Straight Through Serial Cable - DB9 Male to Female Serial Extension Cable 3ft (MXT1003) - serial extension cable - 90 cm
Type Serial extension cable
Length 90 cm
Connector 9 pin D-Sub (DB-9) - male
Connector (Second End) 9 pin D-Sub (DB-9) - female
Colour Grey
Designed For P/N: IC232TTL, ICUSB232D, ICUSB232IS, PEX2S953, PEX2S953LP, PEX4S953, PEX4S953LP
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3 ft Stra...
£3.96
