StarTech.com 3 ft USB Y Cable for External Hard Drive - USB A...
StarTech.com 3 ft USB Y Cable for External Hard Drive - USB A to mini B
£4.41
Select:
12 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Guaranteed reliability
  • No external power adapter required - power your external mini-USB hard drives through two USB ports on your laptop or computer
  • Length: 91cm
  • Stock Status: In Stock
Product codes
Connect and power your external mini-USB equipped hard drive through two standard USB ports on your computer. The USB2HABMY3 3 ft USB-A to Mini-B Y cable features two USB-A male connectors and a single USB Mini-B male connector - an ideal solution for providing additional power to your mini-USB external hard drive by connecting to two USB-A ports on your computer or laptop.
Especially valuable in situations where a single USB 2.0 port may not offer sufficient power to external hard drives, the USB2HABMY3 can be connected to two ports on one PC to increase the power output to power the external device.
Product Description StarTech.com 3 ft USB Y Cable for External Hard Drive - USB A to mini B - USB cable - 91 cm
Type USB cable
Length 91 cm
Connector 2 x 4 pin USB Type A - male
Connector (Second End) Mini-USB Type B - male
Compliant Standards USB / USB 2.0
Colour Black
Designed For P/N: SAT1810U2, SLMSOPTB, PEXUSB7LP
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3 ft USB...
£4.41
