StarTech.com 3 Port 2b 1a 1394 Mini PCI Express FireWire Card...
StarTech.com 3 Port 2b 1a 1394 Mini PCI Express FireWire Card Adapter
£70.21
Delivery:
Standard: 1-3 working days
  • Type: FireWire adapter
  • Compatibility: PC
  • Interface: PCI Express Mini Card
  • Stock Status: In Stock
Product codes
Add 2 FireWire-800 and 1 FireWire-400 port through a Mini PCI Express slot. The MPEX1394B3 3-Port Mini PCI Express FireWire Card is a PCI Express to FireWire-800/FireWire-400 adapter that enables you to add external FireWire connectivity on very small form factor or embedded systems. The PCIe FireWire card provides two FireWire-800 ports and one FireWire-400 port, this adapter card supports the latest external FireWire storage devices at data transfer speeds of up to 800 Mbps. Using the Mini PCI Express (Mini Card) form factor, this adapter card is designed for use in the latest very small form factor computer systems, such as Mini-ITX or custom embedded solutions where a full-sized PCI Express card would not fit.
Product Description StarTech.com 3 Port 2b 1a 1394 Mini PCI Express FireWire Card Adapter - FireWire adapter - PCIe Mini Card - FireWire 800 - 2 ports + 1 x FireWire - MPEX1394B3 - FireWire adapter - 2 ports
Device Type FireWire adapter
Form Factor Plug-in card
Interface (Bus) Type PCI Express Mini Card
Dimensions (WxDxH) 3 cm x 5 cm x 0.4 cm
Weight 6.8 g
Ports Qty 2 ports
Auxiliary Ports 1 x IEEE 1394 (FireWire)
Data Link Protocol FireWire 800
Data Transfer Rate 800 Mbps
System Requirements Linux, Microsoft Windows 2000, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3 Port 2b...
£70.21
