Add 2 FireWire800 and 1 FireWire400 port to any desktop with a PCI slot. This 3 port PCI IEEE 1394a/b FireWire adapter card turns a PCI slot into two FireWire 800 (IEEE 1394b) ports and one FireWire 400 (IEEE 1394a) port - a cost-effective solution that lets you connect FireWire 800 devices as well as older FireWire 400 devices to your desktop computer.
A versatile FireWire solution, the adapter card works in both 5v and 3.3v PCI slots and in 64-bit and 32-bit environments, making it easy to create a high-speed laptop digital media center, or connect demanding FireWire peripheral devices such as portable hard drives, DV camcorders, digital cameras and CD-RW/DVD-RW drives. This high quality adapter card is designed to provide reliable FireWire 800 and FireWire 400 connections.
Product Description | StarTech.com 3 Port 2b 1a Low Profile 1394 PCI Express FireWire Card Adapter - FireWire adapter - 2 ports | Device Type | FireWire adapter | Form Factor | Plug-in card - low profile | Interface (Bus) Type | PCI Express x1 | Dimensions (WxDxH) | 12 cm x 9 cm x 1.8 cm | Weight | 46 g | Ports Qty | 2 ports | Auxiliary Ports | 1 x IEEE 1394 (FireWire) | Data Link Protocol | FireWire 800 | Data Transfer Rate | 800 Mbps | System Requirements | Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux 3.5 to 4.4.x LTS versions, Microsoft Windows Server 2019, Apple MacOS X 10.6 - 10.14 | Manufacturer Warranty | Limited lifetime warranty |
General | |
Device Type | FireWire adapter - 2 ports |
Networking | |
Connectivity Technology | Wired |
Data Link Protocol | IEEE 1394b (FireWire 800) |
Expansion / Connectivity | |
Interfaces | 2 x FireWire 800 - 9 pin FireWire 800 , 1 x FireWire - 6 PIN FireWire |
Compatible Slots | 1 x PCI Express x1 |
Miscellaneous | |
Compliant Standards | FCC, RoHS |
Software / System Requirements | |
OS Required | Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux 3.5 to 4.4.x LTS versions, Microsoft Windows Server 2019, Apple MacOS X 10.6 - 10.14 |
Dimensions & Weight | |
Width | 12 cm |
Depth | 9 cm |
Height | 1.8 cm |
Weight | 46 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Humidity Range Operating | 0 - 90% |
