StarTech.com 3 Port Portable USB 3.0 Hub with Gigabit Etherne...
£43.30
27 in stock
Delivery:
Standard: 1-3 working days
  • Type: USB Hub
  • Ports: 3
  • Stock Status: In Stock
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £46.79
Save £1.50
Add 3 external USB 3.0 ports with UASP and a Gigabit Ethernet port to your Ultrabook or laptop through a single USB 3.0 port. The ST3300GU3B Portable USB 3.0 Hub features an integrated GbE port, enabling you to expand your laptop connectivity by adding three external USB 3.0 ports, as well as a Gigabit network port via a single USB 3.0 connection. This hub is an ideal laptop accessory for your Microsoft Surface Pro 4, Surface Pro 3, Surface Book, Dell XPS 13, and many other devices.
The hub merges Gigabit network support and USB 3.0 hub access into lightweight yet sturdy aluminum casing, providing vital connectivity ports that are often limited or nonexistent on modern mobile computers, while remaining compact and travel-friendly. Plus, with an attached USB 3.0 host connection cable there's no need to carry a separate cable with you, so you can tuck the hub neatly into your laptop bag for maximum portability.
For faster and more consistent network connections, the integrated Ethernet port leverages the 5 Gbps capabilities of the USB 3.0 interface to provide wired Gigabit access that is fully compatible with IEEE 802.3/u/ab standards.
An ideal laptop accessory, this mobile USB hub is great for connecting low-power peripherals like a mouse, keyboard or USB flash drive, and also includes a universal power adapter for connecting devices.
Product Description StarTech.com USB 3.0 Hub with Gigabit Ethernet Adapter - 3 Port - NIC - USB Network / LAN Adapter - Windows & Mac Compatible (ST3300GU3B) - hub - 3 ports
Device Type Hub - 3 ports
Subtype USB
Ports 3 x SuperSpeed USB 3.0 + 1 x 10/100/1000
Features Auto-uplink (auto MDI/MDI-X), full duplex mode
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0, IEEE 802.3az
Power AC 120/230 V
Dimensions (WxDxH) 4.3 cm x 8.7 cm x 1.4 cm
Weight 61 g
Colour Black
System Requirements Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Google Chrome OS, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.6.x to 4.11.x LTS versions, Microsoft Windows Server 2019, Apple MacOS X 10.6 - 10.14
Designed For P/N: PEXUSB3S2EI, PEXUSB3S42, PEXUSB3S7, SVA5H2NEUA
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3 Port Po...
£43.30
