StarTech.com 3 Port USB 3.0 Hub GbE - USB-C - White
£36.15
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Ports: 3
  • Stock Status: In Stock
Product codes
Turn a USB Type-C port on your laptop into three USB Type-A ports (5Gbps) and one GbE port. Here's a must-have accessory for your USB-C equipped MacBook Pro, Chromebook or laptop. This USB 3.0 hub merges your USB peripheral and RJ45 network connections into a single combination hub. It gives you two vital connection types, with Ethernet and USB Type-A, which are often missing from modern laptops.
This 3-port USB hub features an easy-to-use USB-C connector. USB Type-C connectors are easier to insert than past generations. They're small and reversible, and you can connect the plug with either side facing up.
If your MacBook or laptop is missing the ports you need, this hub can help. USB 3.0 is also known as USB 3.1 Gen 1. The versatile USB 3.0 hub gives you access to not only your USB peripheral devices but also a wired internet connection. It offers a Gigabit Ethernet port, so you can connect to a network in locations where Wi-Fi is unreliable or unavailable.
The stylish USB hub features an attractive white finish.
The hub features a rugged yet lightweight housing, so there's no need to sacrifice dependability for portability. Its USB-powered design means you don't need to carry a separate power adapter, so you can tuck the USB 3.0 hub neatly into your travel bag.
This hub is perfect for travel, and it takes up minimal space on a desk, so you can use it in hot-desk or BYOD (Bring Your Own Device) environments.
The hub's built-in USB-C cable makes connections easy, and you don't need to carry a separate cable to attach the hub to your laptop.
Product Description StarTech.com 3 Port USB C Hub w/ Gigabit Ethernet – USB Type C to 3 x USB-A – Multi Port USB 3.0 Hub for MacBook Pro (HB30C3A1GEA) - hub - 3 ports
Device Type Hub - 3 ports
Subtype USB
Ports 3 x SuperSpeed USB 3.0 + 1 x 10/100/1000
Jumbo Frame Support 9KB
Features Full duplex capability, auto-negotiation, VLAN support, wake on LAN (WOL), auto-uplink (auto MDI/MDI-X), plastic housing, USB Attached SCSI Protocol (UASP)
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, USB 1.1, USB 2.0, USB 3.0, IEEE 802.3az
Dimensions (WxDxH) 4.1 cm x 7.8 cm x 1.5 cm
Weight 37 g
Colour White
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3 Port US...
£36.15
