StarTech.com 3 Port USB 3.0 Hub plus Combo Fast-Charge Port (...
StarTech.com 3 Port USB 3.0 Hub plus Combo Fast-Charge Port (2.1A) with Smartphone / Tablet Stand
£19.59
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
  • Type: USB Hub
  • Ports: 3
  • Stock Status: In Stock
Product codes
Add USB 3.0 ports to your Windows based tablet, or any laptop, plus add a separate fast-charge port through a single USB 3.0 connection. This USB 3.0 hub with mobile device stand expands your laptop or tablet connectivity. It works with computers, Windows based tablets, and some On-The-Go-enabled Android devices (when coupled with a separate OTG adapter). Now, you can connect useful peripherals such as a keyboard or an external hard drive to your tablet.
Plus, you can quick-charge a separate mobile device via the integrated fast-charge port.
Unlike most desktop USB 3.0 hubs, this rugged hub is designed with a solid, high-quality housing. Plus, because it's weighted, it remains stationary when you connect or disconnect your devices. Now you can avoid the aggravation of your hub sliding across your desk when it's touched.
Stand makes the hub perfect for mobile devices
This space-saving USB 3.0 hub provides ergonomically-friendly access to your smartphone or tablet via an embedded flip-up stand. The solid-aluminum, retractable stand features a convenient cable-management hole, so you can quickly cradle your host mobile device while neatly organizing your cables.
You can fold the stand down when it isn't need, and because the hub is weighted, there's little risk of a larger tablet flipping over when placed in the stand.
You can overcome port limitations on Android based tablets and smartphones by coupling this hub with a simple UUSBOTG Micro USB to USB OTG Adapter (SKU: UUSBOTG - sold separately). With the adapter, the ST4300U3C1 acts as an OTG hub, letting you connect USB devices to your mobile device.
The hub is also natively supported by many Windows based tablets with a USB-A port.
Alternatively, this small form-factor hub can be used as a traditional USB 3.0 hub, letting you expand your connectivity while remaining backward compatible with USB 2.0 and 1.x devices.
Your mobile device can charge faster via the 2.1A combination fast-charge or data port. You can connect your mobile device as a host or you can fast-charge your device, by simply connecting it to the appropriate fast-charge or host port.
For devices that aren't USB charged (for example, the Microsoft Surface Pro 4), you can cradle and connect it as a host, while continuing to charge it using its own charging mechanism.
Product Description StarTech.com 3 Port USB 3.0 Hub plus Combo Fast Charge Port (2.1A) with Smartphone / Tablet Stand - hub - 3 ports
Device Type Hub - 3 ports
Subtype USB
Ports 3 x SuperSpeed USB 3.0
Compliant Standards USB 1.1, USB 2.0, USB 3.0
Dimensions (WxDxH) 9.6 cm x 12.7 cm x 2.6 cm
Weight 386 g
Colour White, silver
Designed For P/N: PEXUSB3S2EI, PEXUSB3S42, PEXUSB3S7, SVA5M4NEUA
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3 Port US...
£19.59
