StarTech.com 3 Port USB 3.0 Hub with USB-C and GbE 3 ports -...
CLEARANCE
LAST FEW REMAINING
PRICE DROP
StarTech.com 3 Port USB 3.0 Hub with USB-C and GbE 3 ports - Desktop
£53.06
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Ports: 3
  • Stock Status: In Stock
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £56.55
Save £1.50
Turn a USB Type-C port on your laptop into three USB Type-A ports (5Gbps) and one Gigabit Ethernet port. If you have a USB-C equipped laptop, but lack other important connection ports, then this hub can help. It couples your USB peripheral and RJ45 network connections into a single, convenient combination hub. USB 3.0 is also known as USB 3.1 Gen 1.
Through the USB-C host connector, this hub gives you three traditional USB-A ports, and a Gigabit Ethernet connection, making it a must-have laptop accessory. Plus, the integrated 30 cm (12 in.) cable lets you place the hub, your devices, and your network connection, exactly where you need them.
It's ideal for virtually any USB-C equipped laptop, such as the Chromebook Pixel, the Dell Latitude 11 5000 2-in-1, and Dell XPS 12.
This dynamic USB 3.0 hub integrates an easy-to-use USB Type-C connector. It's small and reversible, which makes for easier insertions, and you can connect the plug with either side facing up, which means less risk of damaging your ports and less frustration.
While your USB-C equipped laptop, or MacBook is lightweight and portable, it might be missing vital connectivity ports, such as wired Internet. Because this hub offers a Gigabit Ethernet port, you can connect to a network in locations were Wi-Fi is unreliable or unavailable.
With a small footprint and lightweight housing, you can easily tuck the hub and the included power adapter into your laptop bag to expand your connectivity when you're traveling.
Plus, the compact USB 3.0 hub takes up minimal space on a desk, so it fits perfectly in office, hot-desk (short-term guest), and BYOD workstation environments.
The hub's built-in USB cable is long enough to reach your laptop or tablet's USB 3.0 port, regardless of where the port is located. Now, you can eliminate the worry and frustration when your hub's built-in cable is too short and doesn't reach your laptop's USB port location.
Plus, the extended-length cable provides you with more desk placement options, which makes it easier to create a comfortable, space-efficient work area.
This easy-to-use hub is natively supported in most operating systems, and you can install it quickly, without having to install additional drivers or software. You can also avoid the nuisance and cost of purchasing new devices, by using the USB 3.0 hub with your current USB 2.0 and 1.x devices.
Product Description StarTech.com 3 Port USB C Hub with Ethernet - USB-C to 3x USB-A w/ Power Adapter & Gigabit Ethernet - Thunderbolt 3 Compatible - USB C Network Adapter (HB30C3A1GE) - hub - 3 ports
Device Type Hub - 3 ports
Subtype USB
Ports 3 x SuperSpeed USB 3.0 + 1 x 10/100/1000
Capacity Jumbo frame size: 4096
Features Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), Energy Efficient Ethernet, priority encoding
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, USB 1.1, USB 2.0, USB 3.0, IEEE 802.3az
Power AC 120/230 V / DC 5 V
Dimensions (WxDxH) 4.5 cm x 8.7 cm x 1.4 cm
Weight 44 g
Colour Black
System Requirements Microsoft Windows Server 2008 R2, Apple MacOS X 10.6 or later, Google Chrome OS, Microsoft Windows Server 2012, Microsoft Windows 7 / 8 / 8.1 / 10 (32/64 bits)
Localisation Australia, North America, United Kingdom, Europe
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3 Port US...
£53.06
