This USB Hub adds three USB-A 3.2 Gen 1 (5Gbps) ports and one Gigabit Ethernet port to a USB-C enabled desktop or laptop computer. The USB Hub connects to a USB-C port on a computer, using the built-in 1ft. (30cm) host cable. The USB hub is backward compatible with USB 2.0 (480Mbps) devices, ensuring support for a wide range of modern and legacy USB peripherals (e.g., thumb drives, external HDDs/SSDs, HD cameras, mice, keyboards, webcams, and audio headsets).The USB hub is compact in size, facilitating portability when travelling.
Product Description | StarTech.com 3-Port USB-C Hub with Ethernet, 3x USB-A Ports, Gigabit Ethernet, USB 3.0 5Gbps, Bus-Powered, USB Type-C Hub w/GbE and 1ft/30cm Long Cable, Portable Laptop USB C Hub Adapter - USB Expansion Hub, RJ45 (5G3AGBB-USB-C-HUB) - hub - 3 ports | Device Type | Hub - 3 ports | Subtype | USB | Ports | 3 x USB 3.2 Gen 1 + 1 x micro-USB + 1 x 10/100/1000 | Performance | Data transfer rate: up to 5 Gbps , Throughput (full duplex): up to 2 Gbps | Jumbo Frame Support | 9KB | Features | Flow control, wake on LAN (WOL), full duplex mode, USB powered, plastic housing, priority encoding, USB overcurrent detection and prevention, Energy-Efficient Ethernet (EEE), VLAN Tagging, Automatic Media-Dependent Interface Crossover (MDIX) | Compliant Standards | IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, USB 1.1, USB 2.0, USB 3.0, IEEE 802.3az, USB 3.2 Gen 1 | Dimensions (WxDxH) | 5.4 cm x 42 cm x 1.6 cm | Weight | 82 g | Colour | Space grey | System Requirements | Android, Google Chrome OS, Apple macOS 10.12, Apple macOS 10.13, Apple iPadOS, Apple macOS 10.11, Apple macOS 10.15, Apple macOS 11.0, Apple macOS 12, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Linux Kernel 4.11.x or later (LTS versions only) | Manufacturer Warranty | 2-year warranty |
General | |
Enclosure Type | Desktop |
Subtype | USB |
Processor | X ASIX / VIA VL817 / AX88179A |
Status Indicators | Link/activity |
Expansion / Connectivity | |
Interfaces | 3 x USB 3.2 Gen 1 Type A , 1 x 1000Base-T RJ-45 , 1 x micro-USB input Type B |
Miscellaneous | |
Cables Included | 1 x USB-C cable - 30 cm |
Compliant Standards | Plug and Play, RoHS, WEEE, RCM, UASP (USB Attached SCSI Protocol) |
Software / System Requirements | |
OS Required | Android, Google Chrome OS, Apple macOS 10.12, Apple macOS 10.13, Apple iPadOS, Apple macOS 10.11, Apple macOS 10.15, Apple macOS 11.0, Apple macOS 12, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Linux Kernel 4.11.x or later (LTS versions only) |
Dimensions & Weight | |
Width | 5.4 cm |
Depth | 42 cm |
Height | 1.6 cm |
Weight | 82 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 14.2 cm |
Shipping Depth | 17 cm |
Shipping Height | 3 cm |
Shipping Weight | 138 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years , Technical support - assistance - lifetime |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Humidity Range Operating | 0 - 95% |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 80 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
