StarTech.com 3-Port USB-C Hub w/ Ethernet
£49.10
11 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 3 PORT USB-C HUB: Bus-powered USB 3.2 Gen 1 (5Gbps) expansion hub features a USB-C host connector and 3-port USB-A hub, Overcurrent Protection (OCP) & Wake on USB - Up to 15W of bus power dynamically shared between 3 downstream ports
  • GIGABIT ETHERNET: Features a built-in GbE adapter to provide the reliability and security of wired Ethernet to a laptop or desktop - The GbE controller is fully compatible with IEEE 802.3u/ab standards and supports WoL, Jumbo Frames, and V-LAN Tagging
  • AUXILIARY POWER INPUT: The USB hub features a Micro USB power input (cable sold separately) to add 4.5W (5V/0.9A) of power to the hub for applications where additional power may be required, such as connecting high power USB devices like SSD drives
  • COMPATIBILITY: Supports all major operating systems, incl Windows, macOS, Linux, iPadOS, ChromeOS, Android - Attached 1ft/30cm host cable for easy setup & reduced connector strain on 2-in-1 devices like Surface Pro 7, iPad Pro and laptops on riser stands
  • CONNECTIVITY TOOLS: Optimize the performance and security of this portable USB-A hub, using the included MAC Address Changer, USB Event Monitoring, Wi-Fi Auto Switch utilities (available for download)
  • Ports: 3
Product codes
This USB Hub adds three USB-A 3.2 Gen 1 (5Gbps) ports and one Gigabit Ethernet port to a USB-C enabled desktop or laptop computer. The USB Hub connects to a USB-C port on a computer, using the built-in 1ft. (30cm) host cable. The USB hub is backward compatible with USB 2.0 (480Mbps) devices, ensuring support for a wide range of modern and legacy USB peripherals (e.g., thumb drives, external HDDs/SSDs, HD cameras, mice, keyboards, webcams, and audio headsets).The USB hub is compact in size, facilitating portability when travelling.
Product Description StarTech.com 3-Port USB-C Hub with Ethernet, 3x USB-A Ports, Gigabit Ethernet, USB 3.0 5Gbps, Bus-Powered, USB Type-C Hub w/GbE and 1ft/30cm Long Cable, Portable Laptop USB C Hub Adapter - USB Expansion Hub, RJ45 (5G3AGBB-USB-C-HUB) - hub - 3 ports
Device Type Hub - 3 ports
Subtype USB
Ports 3 x USB 3.2 Gen 1 + 1 x micro-USB + 1 x 10/100/1000
Performance Data transfer rate: up to 5 Gbps , Throughput (full duplex): up to 2 Gbps
Jumbo Frame Support 9KB
Features Flow control, wake on LAN (WOL), full duplex mode, USB powered, plastic housing, priority encoding, USB overcurrent detection and prevention, Energy-Efficient Ethernet (EEE), VLAN Tagging, Automatic Media-Dependent Interface Crossover (MDIX)
Compliant Standards IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, USB 1.1, USB 2.0, USB 3.0, IEEE 802.3az, USB 3.2 Gen 1
Dimensions (WxDxH) 5.4 cm x 42 cm x 1.6 cm
Weight 82 g
Colour Space grey
System Requirements Android, Google Chrome OS, Apple macOS 10.12, Apple macOS 10.13, Apple iPadOS, Apple macOS 10.11, Apple macOS 10.15, Apple macOS 11.0, Apple macOS 12, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Linux Kernel 4.11.x or later (LTS versions only)
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£49.10
