StarTech.com 3-Port USB C to HDMI MST Hub
£104.82
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • MULTIPLE MONITORS: USB-C to HDMI splitter to drive 2x 4K 30Hz or 3x 1080p 60Hz HDMI displays using a USB-C DP Alt-Mode port (DP 1.2/HBR2/MST) w/ no video compression; Thunderbolt 3 compatible
  • CONVENIENCE: With a built-in 1ft cable, this bus-powered 3-port MST hub provides an easy method to connect up to three independent screens with any DisplayPort over USB Type-C Windows host device
  • COMPATIBLE WITH: Dell XPS / Precision / Latitude, Lenovo ThinkPad X1 Carbon / Extreme, Surface Laptop 3 / Book 3 / Pro 7, HP ProBook / EliteBook / Spectre / ZBook & smaller (Mini -ITX) computers
  • INCREASE PRODUCTIVITY: With minimal footprint, this multi stream transport hub helps increase your productivity by adding extended or mirrored displays to your workstation at the office/home office
  • EASY TO USE: This triple or dual monitor adapter uses MST technology to natively support your HDMI monitors allowing for a driverless plug & play setup; fully compatible with Windows systems
  • Stock Status: In Stock
Product codes
Use this USB C hub to connect three independent HDMI displays to a single USB Type-C port. This MST (Multi-Stream Transport) hub lets you connect three HDMI monitors to your USB-C computer. MST ensures hassle-free setup by natively working on any Windows device that supports DP Alt Mode over USB Type-C, such as models of Dell Precision and Dell XPS laptops and ASUS ROG GL752.
The newest generation of laptops are more portable than ever. Unfortunately, this means you're left with fewer video outputs and a small integrated screen. This MST hub solves these problems by letting you connect three displays to a single USB-C port on your computer, which makes multitasking much easier.
Using the MST hub, you can extend your desktop onto additional monitors and stream independent content to each display. This makes it easier to multitask and increase your productivity, which is perfect for creating an easy-to-dock hot-desk solution with a wireless keyboard and mouse peripheral set.
You can also mirror the same image onto multiple displays for remote viewing applications such as digital signage.
MST technology uses your existing video card to minimize the use of system resources while delivering Ultra HD 4K resolutions. 4K is supported by the latest A/V devices and delivers four times the resolution of 1080p. Plus, because the MST hub can output high-definition 1080p, the MST hub is perfect for high-resolution applications such as graphic design and medical imaging.
Product Description StarTech.com 3-Port Multi Monitor Adapter, USB-C to 3x HDMI Video Splitter, USB Type-C DP 1.2 Alt Mode to HDMI MST Hub, Dual 4K 30Hz or Triple 1080p, Thunderbolt 3 Compatible, Windows Only - Multi Stream Transport (MSTCDP123HD) - adapter - HDMI / USB - 30 cm
Cable Adapter - HDMI / USB
Max Output Resolution 3840 x 2160 - 30 Hz
Length 30 cm
Colour Black
Connector USB-C - male (input)
Connector (Second End) 3 x HDMI - female (output)
Compliant Standards Displayport 1.2/Thunderbolt 3
Features 4K30Hz (3840 x 2160) support
Designed For P/N: TB33A1C
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£104.82
