Connect your VGA monitor with the highest quality connection available. The MXTMMHQ30M High Resolution VGA Cable (30-meter) is designed to provide the highest video quality possible through VGA, ideally suited for high resolution applications of 1920x1200 and above.
This durably constructed coaxial VGA video cable (HD15 to HD15) eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial VGA cables, while delivering superior EMI interference protection by using ferrite cores near the connector ends.
Product Description | StarTech.com 30m Coax High Resolution Monitor VGA Video Cable HD15 M/M - VGA cable - 30 m | Type | VGA cable | Technology | Triple shielded twisted pair coaxial | Features | Molded | Length | 30 m | Connector | HD-15 (VGA) - male | Connector (Second End) | HD-15 (VGA) - male | Compliant Standards | RoHS | Colour | Black | Manufacturer Warranty | Limited lifetime warranty |
General | |
Type | VGA cable |
Shielding Material | Aluminum mylar foil with braid |
American Wire Gauge (AWG) | 28 |
Plated Connector | Nickel |
Features | Molded |
Length | 30 m |
Colour | Black |
Connectivity | |
Connector | 15 pin HD D-Sub (HD-15) - male |
Connector (Second End) | 15 pin HD D-Sub (HD-15) - male |
Miscellaneous | |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
