StarTech.com 30m Coax High Resolution Monitor VGA Video Cable...
StarTech.com 30m Coax High Resolution Monitor VGA Video Cable - HD15 M/M
£69.73
Delivery:
Standard: 1-3 working days
  • Length: 30m
  • Stock Status: In Stock
Product codes
Connect your VGA monitor with the highest quality connection available. The MXTMMHQ30M High Resolution VGA Cable (30-meter) is designed to provide the highest video quality possible through VGA, ideally suited for high resolution applications of 1920x1200 and above.
This durably constructed coaxial VGA video cable (HD15 to HD15) eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial VGA cables, while delivering superior EMI interference protection by using ferrite cores near the connector ends.
Product Description StarTech.com 30m Coax High Resolution Monitor VGA Video Cable HD15 M/M - VGA cable - 30 m
Type VGA cable
Technology Triple shielded twisted pair coaxial
Features Molded
Length 30 m
Connector HD-15 (VGA) - male
Connector (Second End) HD-15 (VGA) - male
Compliant Standards RoHS
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 30m Coax...
£69.73
