StarTech.com 34in. Monitor Privacy Screen - Ultrawide - Matte...
StarTech.com 34in. Monitor Privacy Screen - Ultrawide - Matte / Glossy
£151.92
Delivery:
Standard: 1-3 working days
Key features
  • PROTECT SENSITIVE DATA: This 34 inch monitor privacy screen provides privacy/security outside +/-30° viewing angle from the center of your 21:9 34" ultra widescreen display, keeping data on your desktop screen confidential
  • EASY APPLICATION: Attach privacy filter directly to the monitor using residue-free adhesive strips, or slide the filter over your display with included side mounting tabs - Extra adhesive strips and mounting tabs (MON-PRIVACY-SCREEN-K) sold separately
  • BLUE LIGHT REDUCTION: In addition to protecting your data, this PC monitor privacy screen minimizes digital eye strain when working for extended periods of time by reducing blue light by 40% to 51% - Ideal for extended use like when working from home
  • DURABLE & VERSATILE: Flexible dual mounting options fit various monitor bezels to add a durable protective film to the monitor that protects against scratches, fingerprints, & dust
  • REDUCE GLARE OR INCREASE CLARITY: Reversible computer monitor privacy/confidentiality filter retains sharp and consistent image quality in any lighting with an anti-glare matte-finish or a high-clarity glossy-finish
Product codes
Confidentiality Screen Filter - 21:9 Aspect Ratio - Matte or Glossy - 2-Year Warranty
The monitor privacy screen is easy to attach and remove. Simply attach the 34 inch ultrawide privacy screen to your 21:9 aspect ratio display using the attachment strips or slide-mount tabs. This confidentiality screen filter is also reversible. The matte side provides you with glare reduction and the glossy side of the privacy screen will provide you with increased clarity.
Protect Your Privacy
The privacy screen protector for desktop monitors is a great investment if you want to protect your privacy. It is a convenient and cost-effective way to keep your classified information, intellectual property or any other important data you wish to keep protected. You can have a peace of mind while working in the office or public environments because you know your screen is protected with the 30+/- degree privacy viewing angle. The cutout on the top corner of the privacy screen makes it easy to remove for sharing content with trusted audiences or switching between finishes.
Blue Light Reduction
With working from home becoming more prominent and screen time on the rise, reducing blue light exposure is important. The monitor privacy film is designed to filter blue light (390nm~480 wavelength) and reduce digital eye strain.
Antimicrobial Protection
Our privacy screens feature an anti-microbial coating on the matte-side of the filter. Embedded antimicrobial technology provides protection against bacterial microbes by continuously eliminating up to 99.99% of certain surface bacteria. Antimicrobial screen protectors are ideal for environments where disinfection is important.
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales.
The TAA compliant PRIVSCNMON34W is backed by a StarTech.com 2-year warranty and free lifetime technical support.
Product Description StarTech.com Monitor Privacy Screen for 34 inch Ultrawide Display, 21:9 Widescreen Computer Screen Security Filter, Blue Light Reducing (PRIVSCNMON34W) - display privacy filter - 34" wide
Product Type Display privacy filter
Package Content Adhesive strips, slide mount tabs
Colour Transparent
Display Screen Size Compatibility 34" wide
Product Material Plastic
Dimensions (WxDxH) 79.7 cm x 33.5 cm x 0.05 cm
Weight 125 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£151.92
