StarTech.com 35 ft Red Gigabit Snagless RJ45 UTP Cat6 Patch C...
StarTech.com 35 ft Red Gigabit Snagless RJ45 UTP Cat6 Patch Cable
£12.24
Delivery:
Standard: 1-3 working days
Key features
  • 100% copper - a better value
  • 24 AWG wire
  • 50-micron gold connectors
  • Length: 10.7m
  • Colour: Red
  • Stock Status: In Stock
Product codes
Make Power-over-Ethernet-capable Gigabit network connections. The N6PATCH35RD Cat 6 Patch Cable (35 ft) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable red PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Cat 6 Patch Cord delivers reliable performance.
Product Description StarTech.com 35ft CAT6 Ethernet Cable - Red Snagless Gigabit CAT 6 Wire - 100W PoE RJ45 UTP 650MHz Category 6 Network Patch Cord UL/TIA (N6PATCH35RD) - patch cable - 10.7 m - red
Type Patch cable - CAT 6
Technology Unshielded twisted pair (UTP)
Wiring Scheme T568B
Wires per Cable 8 wires
Features Molded, snagless
Length 10.7 m
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour Red
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 35 ft Red...
£12.24
