StarTech.com 36in SATA Serial ATA Cable
£3.80
29 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Fast and easy way to connect Serial ATA/150 hard drives to a motherboard
  • Thinner and more flexible Serial ATA cable is easier to connect inside the system and improves airflow
  • Compatible with both 3.5" and 2.5" Serial ATA devices
  • Length: 0.9m
  • Type: ATA
  • Stock Status: In Stock
Product codes
Connect and position SATA drives easily - designed for larger cases. The SATA36 Serial ATA Cable features two 7-pin data receptacles and supports full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives.
Featuring a low profile, yet durable construction, the flexible design improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
Product Description StarTech.com 36in SATA Serial ATA Cable - SATA cable - Serial ATA 150 - SATA (F) to SATA (F) - 3 ft - red - SATA36 - SATA cable - 0.9 m
Type SATA cable
Interface Speed Serial ATA 150
Length 0.9 m
Connector 7 pin Serial ATA - female
Connector (Second End) 7 pin Serial ATA - female
Colour Red
Designed For P/N: 25SAT35HDD, BRACKET25SAT, CFAST2SAT25, IDE2SAT25, PATA2SATA3, PEXSAT32, PEXSATA22I, S25SLOTR, SAT2MSAT25, SATABAY5BK, SATBP125VP, SATSASBAY3BK, USB2SATAIDE, USB3SSATAIDE
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 36in SATA...
£3.80
