StarTech.com 36in SATA to Right Angle SATA Serial ATA Cable
£4.76
12 in stock
Delivery:
Standard: 1-3 working days
  • Length: 91.4cm
  • Stock Status: In Stock
Product codes
Make a right-angled connection to your SATA drive, for installation in tight spaces. The SATA36RA1 Right Angle (90-degree) SATA Cable features a standard (straight) SATA receptacle as well as a right-angled SATA receptacle, providing a simple 36-inch connection to a Serial ATA drive, with full SATA 3.0 bandwidth support of up to 6Gbps when used with SATA 3.0 compliant drives.
The right-angled SATA connection enables you to plug in your Serial ATA hard drive in hard to reach areas or tight spaces, while the low profile and flexible design of the cable improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
Product Description StarTech.com 36in SATA to Right Angle SATA Serial ATA Cable - SATA cable - 91.4 cm
Type SATA cable
Interface Speed Serial ATA 150/300/600
Features Right-angled connector
Length 91.4 cm
Connector 7 pin Serial ATA - receptacle
Connector (Second End) 7 pin Serial ATA - receptacle
Colour Red
Designed For P/N: PEXSATA24E, SATABAY5BK, SATATRAYBK, SATABAY3BK, SATABAY4BK, PCISATA4R1
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 36in SATA...
£4.76
