StarTech.com 3ft DisplayPort Panel Mount Cable - F/M
£13.29
20 in stock
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
This 3ft panel mount DisplayPort cable features a DisplayPort male connector on one end, and a DisplayPort panel mount (female) molded connector on the other, providing a well-secured, easy to access DisplayPort connection on any machine port or faceplate.
Product Description StarTech.com 3ft DisplayPort Panel Mount Cable - F/M - DisplayPort cable - 91.4 cm
Type DisplayPort cable
Features Latched, molded
Length 91.4 cm
Connector DisplayPort - male
Connector (Second End) DisplayPort - female
Compliant Standards RoHS, NEC-CMG
Colour Black
Designed For P/N: DP2MDPMF6IN
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3ft Displ...
£13.29
