StarTech.com 3ft Slim Micro USB 3.0 Cable
£8.43
24 in stock
Delivery:
Standard: 1-3 working days
  • Length: 1m
  • Stock Status: In Stock
Product codes
Position your USB 3.0 Micro devices with less clutter and according to your configuration needs, with a thin, more flexible cable. This slim, sturdy USB 3.1 Gen 1 (5 Gbps) cable, also known as a USB 3.0 cable, lets you position Micro-USB devices on your desk without the cable getting in the way. It's thinner and more flexible than standard cables, and features a right-angled Micro-USB connector that prevents awkward bends at the connection port.
Now you can arrange your desk according to what works best for you, without worrying about the cable bending awkwardly or straining too much to make a connection. This durable, lightweight cable is roughly half the thickness of a regular USB 3.0 cable, giving you the flexibility and freedom to place your devices as needed, with minimal clutter.
This versatile cable features a right-angled connector, which offers a more natural fit at the device connection point and helps prevent unnecessary strain and damage to the port.
Replace the cable that came with your Micro USB mobile device or keep one as a spare while traveling.
As well as being ideal for connecting to your desktop devices, this cable provides the perfect solution for charging and syncing your USB 3.0 Micro B-equipped phones and tablets.
The cable features a thin, yet sturdy connector molding, so you'll be able to connect to your phone or tablet without removing its protective case. Plus, the cable's right-angled Micro-USB connector lets you text, work or game on your mobile device even while it's charging, without the cable getting in the way.
Product Description StarTech.com 3ft Slim Right-Angle Micro USB 3.0 Cable - M/M - USB 3.1 Gen 1 - USB cable - 1 m
Type USB cable
Technology Shielded
Features Right-angled connector, sync and charge
Length 1 m
Connector 10 pin Micro-USB Type B - male
Connector (Second End) 9 pin USB Type A - male
Compliant Standards USB 3.0
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3ft Slim...
£8.43
