StarTech.com 3ft White Mold Cat5e Patch Cbl
£3.13
Delivery:
Standard: 1-3 working days
Key features
  • 100% copper - a better value
  • 24 AWG wire
  • 50-micron gold connectors
  • Length: 0.9m
  • Colour: White
  • Stock Status: In Stock
Product codes
Make Fast Ethernet network connections using this high quality Cat5e Cable, with Power-over-Ethernet capability. The M45PAT3WH Cat5e Patch Cable (3 ft) meets or exceeds all Cat 5e specifications to ensure reliable Ethernet network connections, and features a durable white PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat5e patch cable features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Cat5e Patch Cord delivers reliable performance.
Product Description StarTech.com 3 ft White Cat5e / Cat 5 Molded Patch Cable 3ft - patch cable - 0.9 m - white
Type Patch cable - CAT 5e
Technology Unshielded twisted pair (UTP)
Wiring Scheme T568A
Wires per Cable 8 wires
Features Molded
Length 0.9 m
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour White
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3ft White...
£3.13
