StarTech.com 3m (10 ft) Long Apple 30-pin Dock Connector to U...
StarTech.com 3m (10 ft) Long Apple 30-pin Dock Connector to USB Cable with Stepped Connector
£22.03
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Overcome distance restrictions and provide full charging power through your USB cable for iPhone, iPod and iPad up to 3 meters distance from your charger
  • Backed by StarTech.com Lifetime Warranty
  • Charge or sync your Apple devices anywhere you go from a computer, USB wall charger, or vehicle USB charger
  • Length: 3m
  • Stock Status: In Stock
Product codes
Charge and sync your iPhone, iPod or iPad at greater distances (up to 3m) with no loss of charge time, even while inside a protective case. The USB2ADC3M Apple (30-pin) Dock Connector to USB cable for iPhone, iPod and iPad (3m) connects your iOS-enabled mobile digital devices to your computer and features a uniquely constructed stepped Apple Dock Connector, designed by StarTech.com. Unlike a regular connector, the exclusive stepped connector plugs into your iPhone, iPod or iPad, even when inside a protective case, avoiding the inconvenience of having to constantly remove the cover for every charge.
This USB to iPhone cable features heavy gauge (20 AWG) wire, which enables convenient syncing and charging of your Apple devices up to 3 meters away from your computer or wall outlet, overcoming distance restrictions while delivering full charging power to your devices with no loss of charge time.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 3m 30-pin Dock to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
Product Description StarTech.com 3m (10 ft) Long Apple 30-pin Dock Connector to USB Cable for iPhone iPod iPad with Stepped Connector (USB2ADC3M) - charging / data adapter - 3 m
Cable Charging / data adapter
American Wire Gauge (AWG) 20
Length 3 m
Colour White
Connector Apple Dock - male
Connector (Second End) USB - male
Designed For Apple iPad (3rd generation); iPad 1; 2; iPhone 3G, 3GS, 4, 4S; iPod (4G, 5G); iPod classic; iPod mini; iPod nano (1G, 2G, 3G, 4G, 5G, 6G); iPod touch (1G, 2G, 3G, 4G)
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3m (10 ft...
£22.03
