StarTech.com 3m (10 ft) White Mini DisplayPort to DisplayPort...
StarTech.com 3m (10 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k
£13.54
13 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Backed by StarTech.com lifetime warranty
  • Cost-effective solution for adding a standard DisplayPort connection to your Laptop or Mac Mini
  • Provides a dependable connection between a Mini DisplayPort-enabled device and a DisplayPort monitor
  • Length: 3m
  • Stock Status: In Stock
Product codes
Connect your DisplayPort monitor to a Mini DisplayPort source. The MDP2DPMM3MW, 3-meter, Mini DisplayPort to DisplayPort Adapter Cable, features a Mini DisplayPort (male) connector on one end, and a DisplayPort (male) connector on the other, allowing you to connect any Mini DisplayPort-enabled laptop (including Mac family of products) to an HDTV, monitor or projector that uses a standard DisplayPort connection.
Product Description StarTech.com 3m 10 ft White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k with HBR2 support - Mini DP to DP Cable (MDP2DPMM3MW) - DisplayPort cable - 3 m
Type DisplayPort cable
Technology Shielded
Features Drain wire
Length 3 m
Connector Mini DisplayPort - male
Connector (Second End) DisplayPort - male
Compliant Standards RoHS
Colour White
Designed For P/N: CDP2MDP, CDP2MDPFC, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDMDP, HD2DP, TB2DOCK4K2DP
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3m (10 ft...
£13.54
