StarTech.com 3m 9.8ft 10G SFP+ DAC Cable
£42.22
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 100% compatibility with HP JD097C guaranteed
  • StarTech.com SFP cables are backed by a lifetime warranty
  • Uses a cost-effective cabling alternative to fiber-optic setups
  • Length: 3m
  • Colour: Black
  • Stock Status: In Stock
Product codes
Connect your HP 10GbE SFP+ network devices with this cost-effective, passive Twinax copper cable. This 10G SFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 10 Gigabit Ethernet applications connected through SFP+ (Small Form-Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies, supporting short-distance applications such as point-to-point in-rack and across-rack network switch or server connections.
Product Description StarTech.com HP JD097C Compatible SFP+ DAC Twinax Cable - 3 m (9.8 ft.) - 10GBase direct attach cable - 3 m - black
Type 10GBase direct attach cable - SFF-8431/SFF-8432
Technology Twinaxial
Features Passive cable
Length 3 m
Connector SFP+ - latched
Connector (Second End) SFP+ - latched
Colour Black
OEM Manufacturer Equivalent Part Number HP JD097C
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3m 9.8ft...
£42.22
