StarTech.com 3m Blue Cat6a Cable STP
£13.46
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Protect your data against noise and EMI/RFI interference
  • RJ45 connector-clip protectors eliminate cable snags and breaks during installation
  • Blue PVC jacket for color coding your connections
  • Length: 3m
  • Colour: Blue
  • Stock Status: In Stock
Product codes
Deliver high-performance 10 Gigabit network connections, free of noise and EMI/RFI interference. This Cat6a cable meets or exceeds all Category 6a cable specifications to ensure reliable 10Gb network connections. The cable is shielded to protect your network against electromagnetic interference (EMI/RFI) and system noise, providing the perfect solution for fast and safe network connections.
This 3-meter blue patch cable is perfect for standard applications such as connecting from a wall jack to your laptop docking station or desktop computer.
For easier network installations, the Cat6a patch cables are available in a wide variety of lengths and colors. This ensures you have the right size of cable available when you need it and it lets you color code your connections for a more organized setup.
Each cable is tested for up to 500MHz frequency and is more than suitable for 10GBase-T Ethernet networks.
Constructed with 100% copper and foil-shielded, twisted-pair wiring, this cable was built for quality performance. The cable is designed to keep the data signals traveling through your network free from interference and is perfect in environments that are prone to large amounts of EMI.
The 50-micron gold connectors deliver optimum conductivity and eliminate signal loss due to oxidation or corrosion.
For trouble-free cable runs, this durable cable features snagless connectors that protect the RJ45 clips during installation, making them less likely to snag or break.
The cable also features molded boots which offer connector strain relief by stopping the RJ45 connector termination points from bending at sharp angles. This reduces the risk of damage to the cable, which could decrease network connectivity and performance.
Product Description StarTech.com 3m Blue Cat6a / Cat 6a Shielded Ethernet Patch Cable 3 m - patch cable - 3 m - blue
Type Patch cable - CAT 6a
Technology Shielded twisted pair (STP)
Shielding Material Aluminium-polyester foil
Wires per Cable 8 wires
Features Snagless, strain relief, PoE ready, RFI/EMI shielding
Length 3 m
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour Blue
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3m Blue C...
£13.46
