StarTech.com 3m DisplayPort to HDMI Cable - 4K
£24.02
Delivery:
Standard: 1-3 working days
Key features
  • Astonishing video quality with support for resolutions up to 4K at 30 Hz
  • Reduce clutter with a compact 3 m (10 ft.) adapter cable
  • Avoid the hassle of converters that require additional cabling and power adapters, with a plug-and-play cable adapter
  • Stock Status: In Stock
Product codes
Eliminate clutter by connecting your DP computer directly to an HDMI display, using this 3-meter cable. This 3-meter (10 ft.) DisplayPort to HDMI adapter cable lets you connect your DisplayPort equipped Ultrabook, laptop or desktop computer to an HDMI television, monitor or projector, with no additional adapters or cables required. The passive adapter supports video resolutions up to Ultra HD 4K, ensuring support for high-resolution applications.
This adapter cable ensures you can maintain an astonishing 4K picture quality, four times the resolution of 1080p, when converting DisplayPort to HDMI. The adapter is also backward-compatible with lower-resolution displays and video sources. With support for high-definition resolutions of 1080p and 720p, you can future-proof your existing setup for 4K video.
For the simplest and most discreet installation, this DP to HDMI adapter connects directly from your DisplayPort video source to the HDMI port on your display. It doesn't need a power source, unlike some converter dongles that require active power and separate bulky video cabling.
With a built-in DP to HDMI adapter, this 3 m cable delivers a direct connection that eliminates the need for additional adapters, ensuring a tidy, professional installation. Plus, because the cable is 3 meters (10 feet) in length, the cable is ideal when connecting your computer to a display that's further away than a standard 6 ft. (2 m) cable.
For shorter or longer installations, a 1 m DP to HDMI cable (DP2HDMM1MB), a 2 m DP to HDMI cable (DP2HDMM2MB) and a 5 m DP to HDMI cable (DP2HDMM5MB) enable you to choose the right cable length for your custom installation needs.
Product Description StarTech.com 3 m (10 ft.) DisplayPort to HDMI Adapter Cable - 4K 30Hz DP to HDMI Converter Cable - Computer Monitor Cable (DP2HDMM3MB) - video cable - DisplayPort / HDMI - 3 m
Cable Video cable - DisplayPort / HDMI
Length 3 m
Connector DisplayPort - male
Connector (Second End) HDMI - male
Compliant Standards DisplayPort 1.2
Features 4K support
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3m Displa...
£24.02
