StarTech.com 3m Dock Connector to USB Cable for ASUS Transfor...
StarTech.com 3m Dock Connector to USB Cable for ASUS Transformer Pad and Eee Pad Transformer Slider
£9.97
Select:
Delivery:
Standard: 1-3 working days
  • Length: 3m
  • Stock Status: In Stock
Product codes
Charge your ASUS Transformer/Slider Tablet up to 3m distance from your power source. The USB2ASDC3M 3m ASUS Transformer USB Cable features one USB Type 'A' male connector and one (40-pin) ASUS male connector, delivering a simple way to connect your ASUS Eee Pad Transformer (TF101, Prime, etc.), ASUS Transformer Pad (Infinity, etc.) or ASUS Eee Pad Slider to a USB-capable computer.
This 3-meter long USB cable for ASUS tablets is twice as long as the standard supplied cable, and allows you to connect your ASUS Pad at further distances from your PC, or Mac Computer for data transfers or from an available power source for charging.
For convenience, this versatile ASUS tablet cable can be connected to a computer USB port for data transfers while you are working. Or you can connect the cable to the USB power adapter which was supplied with your ASUS Pad, for simple charging from an available (wall) power outlet.
This ASUS Transformer USB Cable is designed and constructed for maximum durability, making it a dependable replacement for damaged or misplaced data / charging cables.
Product Description StarTech.com 3m Dock Connector to USB Cable ASUS Transformer Pad / Eee Pad - charging / data cable - 3 m
Cable Charging / data cable
Technology Double shielded
American Wire Gauge (AWG) 30/32
Length 3 m
Colour Black
Connector ASUS 40-pin Dock Connector - male
Connector (Second End) USB - male
Designed For ASUS Transformer Pad TF300T, TF300TG, TF300TL
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3m Dock C...
£9.97
