StarTech.com 3m DVI to VGA Display Monitor Cable M/M - DVI to...
StarTech.com 3m DVI to VGA Display Monitor Cable M/M - DVI to VGA (15 Pin)
£11.52
26 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Cost-effective solution for connecting a VGA Display to a PC or Mac computer with DVI-I analog output
  • Delivers dependable performance, backed by lifetime warranty
  • Ensures a solid, high quality connection between connected devices, using gold-plated contacts and molded connectors with strain relief
  • Length: 3m
  • Stock Status: In Stock
Product codes
Connect a VGA display to a PC or Mac with a DVI Analog Video Card. The DVIVGAMM3M DVI to VGA Display Monitor Cable (3m) features a DVI-A male connector and a VGA male connector, enabling you to connect a VGA display to a PC or Mac computer with a DVI-I analog output.
Product Description StarTech.com 3m DVI to VGA Display Monitor Cable M/M DVI to VGA (15 Pin) - video cable - 3 m
Type Video cable
Technology Shielded
Features Molded, thumbscrews, strain relief
Length 3 m
Connector HD-15 (VGA) - male
Connector (Second End) DVI-A - male
Compliant Standards RoHS
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3m DVI to...
£11.52
