StarTech.com 3m Orange Cat 5e Patch Cable
£3.92
17 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 50-micron gold connectors ensure optimum conductivity while eliminating network signal loss due to oxidation or corrosion
  • RJ45 connector clip protectors help keep the plugs from snagging while routing the cable, for easier Cat5e cable runs
  • Guaranteed reliability
  • Length: 3m
  • Colour: Orange
  • Stock Status: In Stock
Product codes
Make Fast Ethernet network connections using this high quality Cat5e Cable, with Power-over-Ethernet capability. The 45PAT3MOR Cat5e patch cable (3m) meets or exceeds all Cat 5e cable specifications to ensure reliable Ethernet network connections, and features a durable orange PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat5e patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles, reducing the risk of cable failure.
Get the highest value for your cable investment with the Cat 5e cables, each one manufactured using high-quality copper conductors.
Rely on the RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
Product Description StarTech.com 3m Orange Cat5e / Cat 5 Snagless Patch Cable - patch cable - 3 m - orange
Type Patch cable - CAT 5e
Technology Unshielded twisted pair (UTP)
Wires per Cable 8 wires
Features Molded, snagless, minimised Near-End Crosstalk (NEXT)
Length 3 m
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour Orange
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3m Orange...
£3.92
