StarTech.com 3m Purple Cat6 Patch Cable
£4.20
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • RJ45 connector-clip protectors eliminate cable snags and breaks during installation
  • Purple PVC jacket for color coding your connections
  • 3 m in length
  • Moulded RJ45 connectors prevent cable damage and also provide strain relief
  • 50-micron gold-plated connectors for a clear signal
  • High-quality 24 AWG copper wire
  • ETL verified
  • Length: 3m
  • Colour: Purple
  • Stock Status: In Stock
Product codes
StarTech.com N6PATC3MPL. Cable length: 3 m, Cable standard: Cat6, Connector 1: RJ-45. Weight: 109 g. Package width: 200 mm, Package depth: 220 mm, Package height: 10 mm
Product Description StarTech.com 3m Purple Cat6 / Cat 6 Snagless Ethernet Patch Cable 3 m - network cable - 3 m - purple
Type Network cable - CAT 6
Technology Unshielded twisted pair (UTP)
Wiring Scheme T568B
Wires per Cable 8 wires
Features Snagless, stranded, PoE ready
Length 3 m
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour Purple
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3m Purple...
£4.20
