StarTech.com 3m USB 2.0 C to B Cable
£19.63
28 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Simple connections through a reversible USB Type-C connector, which plugs into your device with either side facing up
Product codes
Connect USB 2.0 USB-B devices to your USB-C or Thunderbolt 3 computer. This USB-C to USB-B printer cable lets you connect your USB 2.0 peripheral devices, such as a printer, external drive or scanner to your USB Type-C laptop or tablet. The cable is also compatible with Thunderbolt 3 ports.
The longer cable lets you organize your desk to match your needs, enabling to connect your device up to 3 meters away from your computer.
Product Description StarTech.com 3m / 10 ft USB C to USB B Printer Cable - M/M - USB 2.0 - USB-C cable - 3 m
Type USB-C cable
Length 3 m
Connector 24 pin USB-C - male - straight
Connector (Second End) 4 pin USB Type B - male - straight
Compliant Standards Thunderbolt 3 / USB 2.0
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3m USB 2....
£19.63
