StarTech.com 3m USB 2.0 Type C Cable
£11.04
18 in stock
Delivery:
Standard: 1-3 working days
  • Length: 3m
  • Stock Status: In Stock
Product codes
Charge and sync your USB Type-C mobile devices, over longer distances. This USB-C to USB-C cable makes it easy to charge and sync USB Type-C devices, such as the Samsung Galaxy S8, S8+, Nexus 6P, and 5X phones, using the USB-C port on your computer.
The cable is also compatible with Thunderbolt 3 ports, which means you can charge and sync your USB-C mobile devices using your Thunderbolt 3 laptop.
The 3-meter cable gives you the extra length you need to overcome distance restrictions and stay connected. You can charge and sync your USB-C mobile device, in almost any environment. Even while you're taking notes in a boardroom, catching up on emails in your hotel room, or reading in a coffee shop, your mobile device will reach your computer or wall charger more comfortably.
With up to 3A of power output, you can use this USB Type-C cable to power a USB-C laptop, such as your Apple MacBook or Chromebook Pixel. Simply connect the cable to your USB-C laptop and to a USB-C wall charger.
Replace the USB-C cable that came with your device, or keep one as a spare while you're traveling, so that all of your devices will be ready to use whenever you need them while you're on the road.
Product Description StarTech.com USB-C to USB-C Cable - M/M - 3 m (10 ft.) - USB 2.0 - USB-C cable - 3 m
Type USB-C cable
Technology Shielded
Length 3 m
Connector 24 pin USB-C - male
Connector (Second End) 24 pin USB-C - male
Compliant Standards Thunderbolt 3 / USB 2.0
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3m USB 2....
£11.04
