StarTech.com 3m USB C to DisplayPort Cable - Black
£30.64
Colours:
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Reduce clutter with a USB-C to DisplayPort adapter and display cable, in-one
  • Get astonishing picture quality with support for UHD video resolutions up to 4K 60Hz
  • Make the perfect connection with a monitor cable that works with any USB-C enabled laptop
  • Length: 3m
  • Stock Status: In Stock
Product codes
Use this USB-C to DP cable to connect your USB Type C computer directly to a monitor, without additional adapters. This USB-C to DisplayPort adapter cable offers a convenient solution for directly connecting your DisplayPort over USB Type-C device to your DP monitor or projector. The adapter offers a connection distance of up to 3 m (10 ft.) and works with USB-C devices that support DP Alt Mode, such as the MacBook, Chromebook Pixel and Dell XPS models 15 and 13. It's also compatible with Thunderbolt 3 ports.
At 3 m (10 ft.) in length, this adapter cable delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation.
For shorter installations, StarTech.com also offers a 1 m (3 ft.) USB-C to DisplayPort cable (CDP2DPMM1MB) and 1.8 m (6 ft.) USB-C to DisplayPort cable (CDP2DPMM6B), enabling you to choose the right cable length for your custom installation needs.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K 60Hz monitor or television. This adapter cable lets you harness the video capabilities that are built into your USB Type-C connection, to deliver the astonishing quality of Ultra HD to your 4K display.
Plus, the adapter is still compatible with lower display resolutions, such as 1080p, which makes it a great accessory for your current home, office or other HD work environment, while future-proofing for 4K 60Hz implementation.
Product Description StarTech.com 9.8 ft / 3 m USB C to DisplayPort Cable - 4K 60Hz - Black - external video adapter - STM32F072CBU6 - black
Device Type External video adapter
Bus Type USB-C
Graphics Engine STM32F072CBU6
Max Resolution 3840 x 2160
Interfaces DisplayPort (male connector)
Dimensions (WxDxH) 2 cm 1 cm
Length 3 m
Enclosure Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3m USB C...
£30.64
