StarTech.com 3PT USB 3.0 Hub Power Delivery
£27.19
Delivery:
Standard: 1-3 working days
  • Ports: 3
  • Stock Status: In Stock
Product codes
Turn your laptop's USB Type-C port into three USB Type-A ports (5Gbps), plus power and charge your laptop. This compact USB 3.0 hub lets you add three USB-A ports to your laptop, with support for USB power delivery. This means you can power and charge your laptop through its USB-C port while simultaneously powering the hub.
With its integrated USB Type-C cable and small-footprint design, this versatile hub offers a perfectly portable solution for connecting devices that require traditional USB Type-A ports to your USB-C or Thunderbolt 3 equipped computer.
With its compact and rugged design, you can take this portable USB 3.0 hub anywhere you go. Because it's so compact, it's easy to tuck into your laptop bag and only takes up a small amount of desk space when you connect it to your workstation. For portable applications, having the integrated host (USB-C) cable means one less thing to remember to carry with you.
This USB-C hub 3.0 hub supports USB Power Delivery 2.0, so instead of carrying multiple cables and power adapters, you can use your laptop's USB-C power adapter to power both your laptop and the hub. By using just a single power adapter instead of two, you can eliminate clutter and hassle when you work.
The 3-port USB 3.0 hub offers a built-in USB cable that's long enough to reach your laptop or tablet's USB 3.0 port, regardless of where the port is located. This gives you more desk placement options, which makes it easier to create a comfortable, space-efficient work area.
This USB hub is multi-platform compatible, which means it will work with a wide range of laptops. It also works with a range of operating systems such as Windows, Mac, Linux and Chrome OS. It installs automatically once you connect it to your laptop, so you can be up and running in seconds.
Product Description StarTech.com 3-Port USB 3.0 Hub with Laptop Charging - USB-C to 3x USB-A - USB-C - Built in USB-C Cable - hub - 3 ports
Device Type Hub - 3 ports
Subtype USB
Ports 3 x SuperSpeed USB 3.0
Features USB powered
Compliant Standards USB 1.1, USB 2.0, USB 3.0, USB 3.1
Dimensions (WxDxH) 7.4 cm x 7.2 cm x 1.1 cm
Weight 52 g
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3PT USB 3...
£27.19
