StarTech.com 4 -Port USB-C Hub 10 Gbps - 3x USB-A & 1x USB-C
£54.27
10 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • Adds one USB-C and three USB-A ports to your Mac, Windows, Linux or other USB-C laptop or USB-C enabled tablet (ie. iPad Pro)
  • USB Type-C hub supports USB 3.1 Gen 2 data transfer rates up to 10Gbps
  • Compact, portable design with an extended attached host cable of 9.8" (25 cm)
  • Type: USB
  • Ports: 4
Product codes
Expand the connectivity of your USB-C laptop with this new generation USB-C Gen 2 hub offering 10Gbps supporting greater bandwidth to connected devices and faster data transfer speeds. This bus-powered 4-Port USB-C hub plugs into the USB Type-C or Thunderbolt 3 port on your device, adding one USB-C port and three USB-A ports, so you can quickly connect more USB devices.
This compact, lightweight USB-Type-C hub is a convenient and portable addition to your laptop accessories. The USB-C cable is built-in, and hub is bus-powered, so it draws its power directly from your computer's USB-C port, with no external power required. That means fewer cables to carry with you when you travel. The hub can draw up to 15 Watts of power from the connected host and operating multiple bus powered devices at one time with the total available power dependent on the connected host.
The extended length attached cable of 9.8" (25 cm) provides more flexibility for longer reach connection requirements and plug and play installation.
With ports for both USB-C and USB-A peripherals, this hub is backwards compatible supporting both legacy and new USB devices. You can connect flash drives, video capture devices and external hard drives, with fast data transfer speeds of up to 10 Gbps. This 4-port USB Type-C hub enhances your productivity, giving you the connections you need while you work.
Product Description StarTech.com 4 Port USB C Hub w/ 3x USB A & 1x USB C, SuperSpeed 10Gbps USB Type-C, USB 3.1/3.2 Gen 2 Hub, USB Bus Powered, Compact USB-C to USB Adapter Hub, Portable/Laptop Hub, Aluminum - Windows/macOS/Linux (HB31C3A1CB) - hub - 4 ports
Device Type Hub - 4 ports
Subtype USB
Ports 1 x USB-C + 3 x USB 3.1
Features Auto-uplink (auto MDI/MDI-X), full duplex mode, USB powered, USB Pass-Through
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 2, USB 3.2 Gen 2
Dimensions (WxDxH) 4.5 cm x 10.5 cm x 1.6 cm
Weight 48 g
Colour Black, space grey
System Requirements Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012 (32/64-bits), Microsoft Windows 7 / 8.1 / 10 (32/64 bits), Google Chrome OS 61, Apple MacOS X 10.10 - 10.13, Linux Kernel 4.x LTS, Ubuntu 14.04.x LTS, Ubuntu 16.04.x LTS, Android 8.x
Designed For P/N: PEXUSB321C
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£54.27
