StarTech.com 4 Bay Aluminum Trayless Hot Swap Mobile Rack Bac...
StarTech.com 4 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III
£93.33
Delivery:
Standard: 1-3 working days
  • Type: Storage mobile rack
  • HD Size: 2.5"
  • Stock Status: In Stock
Product codes
Connect and hot swap four 3.5in SATA III or SAS II hard drives to your computer system in three 5.25" bays, with support for transfer speeds up to 6 Gbps. The HSB4SATSASBA Removable 4-drive Backplane makes inserting and removing drives fast and easy, by turning three 5.25" bays into a hot-swappable interface for up to four 3.5" SATA or SAS hard drives (HDD).
For added versatility, the hot swap bay can interface with SATA I/II/III and SAS I/II hard drives - an ideal solution for enterprise system applications.
For a quick and secure method of installing and removing drives, the backplane features ejection levers and a key-lock design. To help prevent drive failure, the bay provides drive cooling with a built-in fan and excellent heat dissipation with a vented aluminum enclosure.
Product Description StarTech.com 4-Bay Mobile Rack Backplane - Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III - 6 Gbps HDD (HSB4SATSASBA) - storage mobile rack
Device Type Storage mobile rack
Colour Black
Expansion Bays 4 x hot-swap - 3.5"
Compatible Bay 3 5.25"
Hard Drive Form Factor Compatibility 2.5"
Supported Interface SATA-600
Drive Connector 29 pin internal SAS (SFF-8482)
Features Data indicator, power indicator, cooling fan
Product Material Aluminium
Dimensions (WxDxH) 14.5 cm x 19.8 cm x 12.5 cm
Weight 120 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4 Bay Alu...
£93.33
