StarTech.com 4 Drive 3.5in Trayless Hot Swap SATA Mobile Rack...
StarTech.com 4 Drive 3.5in Trayless Hot Swap SATA Mobile Rack Backplane
£87.87
Delivery:
Standard: 1-3 working days
Product codes
Hot swap up to four 3.5in SATA hard drives in seconds. This 4 Bay SATA Mobile Rack lets you swap between 3.5in Serial ATA (SATA, SATA II, SATA III-6Gbps) hard drives in seconds.
A time saving storage solution, the mobile rack offers four trayless SATA hard drive bays, allowing you to hot swap Serial ATA hard drives but avoid having to mount the drives to trays for deployment or unfasten them for replacement.
To maximize performance and utilize the full speed potential of your SATA III hard drives, this HDD Backplane supports SATA III for transfer speeds up to 6 Gbps when paired with compatible controller.
Supporting up to four hard drives, the mobile SATA hot swap rack only takes up three 5.25in drive bays inside a host computer - maximizing space-efficiency within the computer. The mobile rack/backplane is fully compatible with RAID installations to ensure maximum performance and versatility for enhanced storage applications.
Using Terabyte hard drives? Don't expose your Hard Drive and valuable data to unnecessary heat!
The HSB430SATBK has two built-in 40mm fans that re-distribute the heat build-up generated as a result of typical drive operation. This feature is especially important for larger volume storage drives, and faster "spinning" drives (i.e 7200 RPM), as it can help optimize drive operability and in turn preserve stored data integrity.
Product Description StarTech.com 4 Drive 3.5in Trayless Hot Swap SATA Mobile Rack Backplane - storage drive cage
Device Type Storage drive cage
Colour Black
Expansion Bays 4 x hot-swap - 3.5" x 1/3H
Compatible Bay 4 5.25" x 1/2H
Hard Drive Form Factor Compatibility 3.5"
Supported Interface SATA 3 Gb/s
Drive Connector 7 pin Serial ATA
Bay Connector 7 pin Serial ATA
Features 2 fans, data indicator, power indicator
Product Material Aluminium
Dimensions (WxDxH) 14.6 cm x 19.4 cm x 12.7 cm
Weight 1.4 kg
Designed For P/N: PEXSAT34RH
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4 Drive 3...
£87.87
