StarTech.com 4 Port Black SuperSpeed USB 3.0 Hub
£32.40
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Connect USB 3.0 and older USB devices simultaneously at their respective maximum speeds with USB 2.0/1.x backward compatibility
  • Connect high powered USB devices with the included external power adapter, or simply use as a bus-powered hub
  • Type: USB Hub
  • Interface: SuperSpeed USB 3.0
  • Speed: 5Gbps
  • Ports: 4
  • Form Factor: External
Product codes
The ST4300USB3GB 4-Port SuperSpeed USB 3.0 Hub allows you to add 4 additional USB 3.0 ports from a single USB 3.0 connection to the host computer system.
Backward compatible with USB 2.0 and USB 1.x standards, this USB 3.0 hub still supports older USB devices and can also be used as a hub on older systems that do not have USB 3.0 ports.
With the capability to mix and match USB 3.0/2.0/1.x devices and be used with or without the included external power adapter, this hub offers the best of versatility and portability.
Product Description StarTech.com 4 Port Black SuperSpeed USB 3.0 Hub - hub - 4 ports
Device Type Hub - 4 ports
Subtype USB
Ports 4 x SuperSpeed USB 3.0
Compliant Standards USB 1.1, USB 2.0, USB 3.0
Dimensions (WxDxH) 6.8 cm x 9.5 cm x 2.3 cm
Weight 55 g
Colour Black
System Requirements Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition
Localisation United Kingdom
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4 Port Bl...
£32.40
