StarTech.com 4 Port Black USB 2.0 Hub
£16.40
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Comes complete with a wall-mount power adapter and a 3 ft. USB 2.0 A/B male-to-male cable
  • Type: USB Hub
  • Interface: USB 2.0
  • Speed: 480Mbps
  • Ports: 4
  • Form Factor: External
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £19.89
Save £1.50
Turn a single USB 2.0 port into 4 external USB 2.0 ports.
This 4 Port USB 2.0 Hub connects to one USB 2.0 port on a Mac or PC computer, adding four USB 2.0 ports - allowing you to maximize the number of high speed USB peripherals connected to your computer. The hub supports cascaded installation with other USB 2.0 hubs, supporting up to 127 USB 2.0 device connections - a scalable solution for connecting multiple USB devices to a single host computer.
The 4 port hub includes a power adapter, but can be powered through USB bus connection to the host computer - allowing you to install the hub as needed without worrying about the availability of a power outlet.
The USB 2.0 hub offers an attractive black casing that suits any operating environment and includes a 3ft USB 2.0 A/B male-male cable, for the connection between the hub and the host computer.
Product Description StarTech.com 4 Port USB 2.0 Hub - Hub - 4 ports - Hi-Speed USB - hub - 4 ports
Device Type Hub - 4 ports
Subtype USB
Ports 4 x USB 2.0
Compliant Standards USB 1.1, USB 2.0
Dimensions (WxDxH) 6.8 cm x 9.7 cm x 1.9 cm
Colour Black
System Requirements Apple MacOS 8.6 or later, Microsoft Windows 98SE/2000/ME/XP, Microsoft Windows Vista, Microsoft Windows 2003
Localisation United Kingdom
Manufacturer Warranty 1-year warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4 Port Bl...
£16.40
