StarTech.com 4 Port Low Profile Native RS232 PCI Express Seri...
StarTech.com 4 Port Low Profile Native RS232 PCI Express Serial Card with 16950 UART
£78.33
10 in stock
Delivery:
Standard: 1-3 working days
Product codes
Add 4 high-speed RS-232 serial ports to your PC through a low profile PCI Express expansion slot. The PEX4S952LP 4 Port Low Profile Native RS232 PCI Express Serial Card (16950 UART) turns a PCI Express slot into four RS232 (DB9) serial connections.
The card is constructed using a native single chip design that lets you harness the full capability offered by PCI Express (PCIe), while reducing the load applied to the CPU by as much as 48% over conventional bridge chip serial cards.
The PCI Express RS232 Serial Adapter Card is compatible with a broad range of operating systems, including Windows 2000/XP/2003/Vista, Linux Kernel 2.6.11 and up, and ships with a half-height/low profile bracket installed, but also includes an optional full profile bracket that lets you add four serial ports to virtually any computer (regardless of the case form factor).
StarTech.com 4 Port Low Profile Native RS232 PCI Express Serial Card with 16950 UART - serial adapter
Serial adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x1
PCI Specification Revision
PCIe 1.0a
Ports
RS-232 x 4
2 cm x 9 cm x 8 cm
58 g
RS-232
Data Transfer Rate
460.8 Kbps
1 x OXPCIe954 - Oxford Semiconductor
Microsoft Windows Server 2003, Linux 2.6.x or later, Microsoft Windows Vista / 2000 / XP
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4 Port Lo...
£78.33
