StarTech.com 4 Port Low Profile Native RS232 PCI Express Seri...
StarTech.com 4 Port Low Profile Native RS232 PCI Express Serial Card with 16950 UART
£78.33
10 in stock
Delivery:
Standard: 1-3 working days
  • Type: Serial adapter
  • Compatibility: PC, Unix
  • Interface: PCI Express x1
  • Stock Status: In Stock
Product codes
Add 4 high-speed RS-232 serial ports to your PC through a low profile PCI Express expansion slot. The PEX4S952LP 4 Port Low Profile Native RS232 PCI Express Serial Card (16950 UART) turns a PCI Express slot into four RS232 (DB9) serial connections.
The card is constructed using a native single chip design that lets you harness the full capability offered by PCI Express (PCIe), while reducing the load applied to the CPU by as much as 48% over conventional bridge chip serial cards.
The PCI Express RS232 Serial Adapter Card is compatible with a broad range of operating systems, including Windows 2000/XP/2003/Vista, Linux Kernel 2.6.11 and up, and ships with a half-height/low profile bracket installed, but also includes an optional full profile bracket that lets you add four serial ports to virtually any computer (regardless of the case form factor).
Product Description StarTech.com 4 Port Low Profile Native RS232 PCI Express Serial Card with 16950 UART - serial adapter
Device Type Serial adapter
Form Factor Plug-in card - low profile
Interface (Bus) Type PCI Express x1
PCI Specification Revision PCIe 1.0a
Ports RS-232 x 4
Dimensions (WxDxH) 2 cm x 9 cm x 8 cm
Weight 58 g
Data Link Protocol RS-232
Data Transfer Rate 460.8 Kbps
Processor 1 x OXPCIe954 - Oxford Semiconductor
System Requirements Microsoft Windows Server 2003, Linux 2.6.x or later, Microsoft Windows Vista / 2000 / XP
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4 Port Lo...
£78.33
