StarTech.com 4 Port Native PCI Express RS232 Serial Adapter C...
StarTech.com 4 Port Native PCI Express RS232 Serial Adapter Card with 16550 UART
£75.12
10 in stock
Delivery:
Standard: 1-3 working days
  • Type: Serial adapter
  • Compatibility: PC
  • Interface: PCI Express 1.1 x1
  • Stock Status: In Stock
Product codes
The PEX4S553 4-Port Native PCI Express RS232 Serial Adapter Card with 16550 UART lets you add 4 RS232 (DB9) serial ports, using a single PCI Express expansion slot.
Based on a native single-chip design, this 4-port serial adapter card allows you to harness the full capability offered by PCI Express (PCIe), while reducing the load applied to the CPU by as much as 48% over conventional bridge-chip serial cards.
The RS232 Serial Adapter Card includes 4 half-height/low-profile brackets, allowing the card to be installed into almost any PC case, regardless of form factor.
Product Description StarTech.com 4 Port Native PCI Express RS232 Serial Adapter Card with 16550 UART - serial adapter - 4 ports
Device Type Serial adapter
Form Factor Plug-in card
Interface (Bus) Type PCI Express 1.1 x1
Dimensions (WxDxH) 1.9 cm x 13 cm x 12 cm
Weight 80 g
Ports Qty 4 ports
Data Link Protocol RS-232
Data Transfer Rate 128 Kbps
Processor 1 x MCS9904CV-AA - MosChip Semiconductor
System Requirements Linux, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4 Port Na...
£75.12
