StarTech.com 4 Port Native PCI Express RS232 Serial Adapter C...
StarTech.com 4 Port Native PCI Express RS232 Serial Adapter Card with 16950 UART
£78.33
42 in stock
Delivery:
Standard: 1-3 working days
Key features
  • High Performance Dual Channel Oxford 950 UART
  • Less load on the CPU
  • Native single-Chip, single lane PCI Express
  • Standard and low profile bracket included
Product codes
Add four RS232 serial ports to any PC using a single PCI Express expansion slot. The PEX4S952 4 Port Native PCI Express RS232 Serial Adapter Card with 16950 UART allows you to turn a PCI Express slot into 4 RS-232 (DB9) serial connections.
The four port serial card is based on a native single chip design, that harnesses the full capability of PCI Express (PCIe) - providing optimum reliability and speed, and reducing the load applied to the CPU by as much as 48% over conventional serial cards.
Offering compatibility with a broad range of operating systems including Windows, Linux and Mac OS for easy integration into mixed environments. Plus, an included optional low profile/half-height bracket that allows the card to be installed in virtually any computer case - making it that much easier to add serial ports to your PCI Express enabled computer, regardless of the case form factor.
StarTech.com 4 Port Native PCI Express RS232 Serial Adapter Card with 16550 UART - serial adapter
Serial adapter
Plug-in card
Interface (Bus) Type
PCI Express x1
Ports
RS-232 x 4
2 cm x 9 cm x 6.5 cm
58 g
RS-232
Microsoft Windows 2000 / XP, Apple MacOS X 10.4 or later, Microsoft Windows Vista, Microsoft Windows 2003, Windows 10 (32/64 bits)
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4 Port Na...
£78.33
