Add four RS232 serial ports to any PC using a single PCI Express expansion slot. The PEX4S952 4 Port Native PCI Express RS232 Serial Adapter Card with 16950 UART allows you to turn a PCI Express slot into 4 RS-232 (DB9) serial connections.
The four port serial card is based on a native single chip design, that harnesses the full capability of PCI Express (PCIe) - providing optimum reliability and speed, and reducing the load applied to the CPU by as much as 48% over conventional serial cards.
Offering compatibility with a broad range of operating systems including Windows, Linux and Mac OS for easy integration into mixed environments. Plus, an included optional low profile/half-height bracket that allows the card to be installed in virtually any computer case - making it that much easier to add serial ports to your PCI Express enabled computer, regardless of the case form factor.
Product Description | StarTech.com Serial adapter card - PCI Express - serial - 4 ports - serial adapter | Device Type | Serial adapter | Form Factor | Plug-in card | Interface (Bus) Type | PCI Express x1 | Ports | RS-232 x 4 | Dimensions (WxDxH) | 2 cm x 9 cm x 6.5 cm | Weight | 58 g | Data Link Protocol | RS-232 | System Requirements | Microsoft Windows 2000 / XP, Apple MacOS X 10.4 or later, Microsoft Windows Vista, Microsoft Windows 2003, Windows 10 (32/64 bits) | Manufacturer Warranty | Limited lifetime warranty |
General | |
Networking | |
Connectivity Technology | Wired |
Features | Software flow control, hardware flow control |
Expansion / Connectivity | |
Interfaces | 4 x RS-232 - 9 pin D-Sub (DB-9) |
Compatible Slots | 1 x PCI Express x1 |
Miscellaneous | |
Compliant Standards | FCC, RoHS |
Software / System Requirements | |
OS Required | Microsoft Windows 2000 / XP, Apple MacOS X 10.4 or later, Microsoft Windows Vista, Microsoft Windows 2003, Windows 10 (32/64 bits) |
Dimensions & Weight | |
Width | 2 cm |
Depth | 9 cm |
Height | 6.5 cm |
Weight | 58 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
